SVEN-AKE'S WEB SITE
Date:  5-19-2014
Number of Hours:  4.00
Manual Reference:  chapt 8
Brief Description:  firewall finished
When installing lower bearing, I found only 2 bolt-holes drilled in right position of black plastic bearing. Not mentioned in manual, butI drilled 4 new. Installed AN3-6 bolt, washer and locknuts temporary. Will be torqued later when nose-gear is installed.
Mounted upper bearing together with stiffernes and angles. Removed clecos from diagonal angles on rear side, and rivet from frontside. Also 6-W-6-1 angle rivered from front side.
lower bearing
lower bearing
upper stifferner and bearing
