Removed throttle body and drilled a hole for MAP hose fitting. Use a M5 tap for thread. A 5mm fitting was fabricated from an AL bar, and inserted in throttle housing. Aircleaner 291209358602 was fitted to throttle housing. 8mm vacum hose connected from inlet to DACU.
