Brief Description: test mount cowling and radiator
With cowling and radiator in position, I start to measure. I am aware of a spacer has to be used, or maybe an extra long propeller hub. After consluting D-motor I now know that max 20mm spacer is OK. And no more than 50mm longer propeller hub is allowed. WhatI found possible now, is to order a 50mm longer hub. And some minor modifications on cowling.
