After 2 hour eng time, I performed an initial pressure test. Measured values: 77-78 psi on all cylinder. OK. Propeller retorqued, 28Nm. Continued with a wheelbearing check. Nose wheel bearings need to be adjusted. This was the start of first annual linspection.
