The rubber C shape from kit didnĀ“t fit so well. The upper skin on wings were designed for use with resque parachute straps between fuselage and wing. Without BRS the opening is far to big. Finally I found a L-shaped rubber seal that cover opening in a good way. The 1-717 seal was bonded to fuselage with Loctite 480,
