Check that all fuellines are connected and secured. No fuel in tank. Calibrate fuelmeter empty. 82 Ohm. Fill 1 liter in right tank, check possible to drain, check fuel pressure and fuel return to tank. OK Fill 20 liter, mark level on side of tank, from baggage locker. Sender 57 Ohm. Fil to neck. Total 38 liter. Calibrate fuelmeter full 2 Ohm. Check for leakage. To measure fuelpump capasity I disconnect return line after pressure regulator. Connect a fuelhose and measure time to fill 1 liter container with returnfuel. Returnflow at 3 bar pressure is 128 liter/hour. Max possible fuel consumption is rated 26,4 liter/h at 90hp/3000 rpm. This makes about 500%.
