The opening in side skin, where canopy handle will be installed, is to big to fit. I fabricated a small AL-plate, with a smaller hole, and fit it on inside. Holes drilled for attaching screws, Anchor nuts rivetted on inside. A 2 mm fiberglass sheet was cut and formed on outside. This will stiff up the tiny skin a lot. 2 M5 SS screws hold the handle.
