From fuelvalve I earlier installed AN6 tubes through center consol and now it was time to connect to fuselage sides. The holes drilled from ICP was too big to fit the AN 832 fittings. A 50x50mm AL-plate drilled to correct size and mounted on inside fuselage skin with 3 rivets. On both sides.
