Recived the oilcooler today, a Laminova heat exchanger C43-92. My idea is to use a thermostat, AP8124929, to keep cooling water at a stable level. What the heat exchanger do is retaining oil and coolant temp equal. Initially oil is heated up by the coolant, and when oil-temp rises coolant will keep it down. First test assembly today with use of silicone hoses and Al-tubes from DO-88.
