The two high pressure fuelpumps needed a bracket designed for 52mm, many Bosch pumps are normally 55mm. I did found a double bracket, with rubber inserts. P/N 300949092205. I positioned pumps on right side of firewall, close to gascolator. I used two M8x25mm bolts, washers and locknuts for connection. I used AN816-6D to connect to gascolator, together with AN818 nut and AN819 sleeve. Versatube 3/8. Pumps have a 12mm inlet, which gave me something to think about. Some 3/8" chromeplated brass Tees and elbows together with10 and 12mm hose fittings. 1/2" fuelhose and clamps connect to pumps.
