With help pf the temporary motormount I fabricated earlier, the engine was mounted on airframe. To check space for cowling, radiator, exhaust system, oiltank and electrical system. A motor mount is under design, and must be rechecked before welding. The Rotax cowling seems to fit, possible conflict areas are radiator, exhaust and maybe a spacer has to be added between engine and propeller. Cowling is very narrow in front end.
