I fitted the stabilizer tips, and used 3,2 mm rivets. There was some minor adjustments and sanding of fiberglass to get a better fit. Than trim was fitted, everything was prepared, only rivet motor to skin. connect cables, and install AN3-05 bolt with locknut. Before painting I started to polish the stabilizer, a dirty job. Will take some time.
