Brief Description: baggage carpet, and safety belts
After some searching I found a thin grey carpet in a local store. NÃ¥lfiltsmatta. I cut it to cover baggagefloor and sides up to longeron. And use double sided tape to hold it in position. Picked up Safety belts and found that holes in aluminium washers SF740 are not in correct size. Now enlarged to 8mm. Bolts AN5-06, with washers and stopnuts. 2 of SF740 washers are cut to fit inside "A-connection".
