This week I have been working on and off with pedals. Start with primer and topcoat on pedals, 6-B-9-1L+R. Again I had to remove some rivets, this time from boltholes for pedal bearings. Installed bearings SF 417, after some grinding work they fit. I used AN3-15A bolts, washers and locknut. Double washers on the 3 bolts in center. I connected rudder cables 6-B-23-51 with bushing SC134, double AN5 washers, bolt AN3-05 and stopnut with cotterpins. On left side I installed brakepumps 90MT-MT5 with AN3-11 bolts, washers, and stopnuts. I understand that brackets was not equally installed on both side, there is a need for longe bolt on right bracket. Installed AN3-7 bolt in upper position. With washer and locknut. Connector 944RA18L6 for brake pipe is installed with Locktite 577.
