Temporary installed pedal reinf. 6-B-8-58 and supports -9-6 on floor after removing 8 rivets installed earlier. Drilled 6 extra holes and rivet all parts again. Inserted rivnuts under fuselage aft of maingear channel. I have to lift up fuselage higher, to make it possible to install all rivnuts. Leave this for a while. According to manual upper skins should be installed earlier, but I will wait. Easier to see and install interior without cover everything. Trapdoor should be installed with camlocks, but I didnĀ“t found any 2,5 mm countersunk rivets. Too special for the local hardware store. Will order.
