Today I installed control panel frames with gussets, primered yesterday. But to do this I had to remove some rivets installes some weeks ago. There are now 2 extra aluminium sheets under gas damper rear brackets rear end. I guess it will be better to add some extra plates under 2 fwd rivets also. Today I got an answer from ICP about there will not be any gas damper on right side, and as I see it no use for right hand bracket. I also installed angles 6-K-2-1R+L and plate 6-K-2-51. In baggage area 6-B-15-53L+R.
