Prepared bearings for torque tube, deburr and primer. Rivet 6-B-19-5, -19-51 and -19-50 with extra long 4 mm rivets. After some cutting inside plastic bearing, it was possible for axle to slip in. Installed both bearings with AN3-05A bolts, washer and locknuts. Torqued to 5 Nm.
