Brief Description: lower eng mont and maingear support
Cleaned engine mont 6-B-6-5L+R and main gear support 6-B-11-4L+R. Add primer and paint them with Hammerite silver. Enlarged the holes for AN3-05 bolts in bottom skin, and drill holes in firewall for temporary screws. To get bracket in right position. Some minor adjustments even for main gear support. AN3-05 bolt used with double washers according to manual. Torqued to 5 Nm, and some 4 mm rivets installed. All tasks up to page 15 in chapter 9, fuselage, now compleated.
