After cleaning the skin and remove primer from all holes it was time to use the last clecos. Now I found that the bottom skin had to be tweaked up 90 degrees in the rear part. Removed skin again and bend it on both sides. Some more adjustments on Center spar and it fits quite well. Ordered more clecos. Now I can see the shape of an aircraft.
