Adjusted wiring to the trim tab. Removed Cleco and riveted together underside of the stabilizer. Installed elevator-hingle on stabilizer side. Since the hinge is slightly shorter than stabilizer and elevator, a spacer on each side are used to keep skin straight. But unfortunately, hinges and shims are of different thickness. Next time I will fabricate my own.
