Larrys Exp PA18 Supercub
Date:  11-9-2014
Number of Hours:  3.00
Brief Description:  Door jamb
Today I work on the door jamb area fabricating for the swinging doors. The two round tubes with the washers are welded together and go inside longeron tube and welded, that was cut for the doors. They are so when you drill the hole for the door pin latch, water won’t get in the longeron.
