Sonnys CH650
Date:  12-29-2013
Number of Hours:  0.90
Manual Reference:  Dwg 6AT0
Brief Description:  Actuator Access Hole
Created 72 x 72 access hole for trim tab actuator and rod.
Used hole saw to create large round opening
Created 1/4" radius in each corner by step drilling down to 1/2" diameter
Rough cut sides by tin snipping corner to corner
Filed sides straight and tangential to corner radii
Finished up corners by hand-sanding with 1/2" spindle sanding cylinder
Deburred entire perimeter
Fabricated 110 x 110 cover plate from 0.025"
Beveled edges for tight fit to skin
Hole and Tools
Hole and Tools
Cover Plate
Cover Plate
