Sonnys CH650
Date:  2-25-2012
Number of Hours:  0.40
Manual Reference:  Dwg 6W2
Brief Description:  Aileron Test Strip
Used bend line spreadsheet to calculate sight lines locations at 18.5, 112.5 and 422.5 with a total developed length of 767.5mm. Marked these dimensions on a 20mm test strip then bent on brake. Fit to rib was as close to perfect as I care to achieve.
Test Strip on Rib
Test Strip on Rib
Flex Hinge
Flex Hinge
Aileron Profile Drawing
