Sonnys CH650
Date:  2-13-2011
Number of Hours:  5.00
Brief Description:  Drilled Bending Brake Hinges
Spent some time cleaning up the angle iron with a sanding wheel and wire brush using my angle grinder. Match drilled each of the two 5' hinges to the bottom plate and bending plate using a 3/16" cobalt drill. The hole spacing is 4" (64 total) and they are staggered high-low for torsional load distribution. I noted that other builders of this brake removed the hinge pin and drilled each half separately but - unless I'm missing something - I have not yet found this necessary. Punched matching dimples to each hinge-half and it's mating brake plate to ensure I don't waste time trying to figure out what goes where when it's time to reassemble all the parts after deburring, cleaning and priming.
Hinge to Bottom Plate
Hinge to Bend Plate
Hinge to Bend Plate
Part ID/Match Dimples
