Sonnys CH650
Date:  12-17-2011
Number of Hours:  1.70
Manual Reference:  6T6 p 1
Brief Description:  Drilled Trim Tab Hinge Line
Marked hinge rivet line 8mm from top edge of trim tab. Marked 23 hole locations along the line which came out at the 40mm pitch specifed on drawing. Noted that the left elevator rib line does NOT end on one of the hinge rivets.
Clamped trim tab between steel bar and strip of wood then applied clamp force to bring the top edge and radius of inside flange up to the same vertical plane. Pilot drilled holes with a depth stop on the drill bit to ensure it didn't get into the web or bottom of the tab.
Setup for Drilling
Setup for Drilling
Drilled on 40mm Pitch
