Sonnys CH650
Date:  9-22-2011
Number of Hours:  0.50
Manual Reference:  Dwg 6T2-4
Brief Description:  Pilot Drilled Top of Skin
Pilot drilled the front spar line and center ribs. The rear spar line will be layed out after trimming to match the spar and establishing distance based on hinge width.
Using the end ribs as guides I was unable to establish anything close to a 60 pitch that did not result in a hole falling on a rib crimp. So, these locations will be establised after the ribs are positioned in the closed-up stab.
Clecod to bench
Clecod to bench
