STUART'S WEB SITE
Date: 7-7-2013
Number of Hours: 1.50
Brief Description: Rudder Horn Brace.
A TRAP FOR YOUNG PLAYERS,WHEN CUTTING THE R-710 RUDDER HORN BRACE AS PER INSTRUCTIONS FROM CENTRE OF NOTCH TO THE OPPOSING NOTCH CENTRE,VANS INSTRUCTIONS FAILED TO INDICATE THAT WHEN THE TASK IS PERFORMED,CUT ON THE HIGH SIDE,TO ALLOW DEBURRING TO TAKE PLACE WITHOUT BREACHING THE MINIMUM EDGE DISTANCE RULE.TO DISCOVER THIS YOU NEED TO DESTROY ONE THEN MATCH DRILLING THE LOWER RUDDER RIB,AND SKIN,IT BECOMES OBVIOUS.THE R-710 HAS A CENTRE HOLE ( CHRIST KNOWS WHAT FOR ,VANS DIDN'T KNOW EITHER ),WHEN THE CUT IS COMPLETE BETWEEN NOTCHES,THIS CENTRE HOLE WILL STILL EXIST.VANS ( WHEN EMAILED ) SAID TO JUST ROUND THE LEFT OVER CENTRE HOLE. SOOOOOOOO ONE NEW RUDDER BRACE HORN $11.95, FREIGHT TO CHARLEVILLE QUEENSLAND AUSTRALIA,$45.00
