Brocks RV-7A
Date:  10-15-2012
Brief Description:  Back to Work!
After a long break due to a series of projects, I am back to work. Today, I began by assembling the fuel sender. The float arm was cut to length and bent as appropriate. I then fabricated the fuel pick-up tubes. The fuel pick up tubes and vent lines were flared and prepped for connection. The access plate assembly was then assembled.
