Brocks RV-7A
Date:  6-19-2012
Number of Hours:  5.00
Brief Description:  Spars Attached to Stand, Ribs Attached to Spar
Today, I attached my main wing spars to the wing stand I built earlier. I then attached all wing ribs to the main spar and attached the rear spar to the ribs using clecos. I then drilled all spar to rib holes to the propper size. Next, I disassembled the wing skeleton in order to debur and prime the wing ribs.
