Brief Description: Prepping the Trailing Edge of the Rudder
Today, I obtained an aluminum L bar and drilled holes to match with the rivet holes on the trailing edge of the rudder. I obtained a 2-part aluminum expoxy and glued the skins to the AEX bar. I then cleco'd the entire assembly together and removed excess expoxy. The assembly was left in place to cure.
