Today, I completed the F-712 bulkhead. I then attached the F-711 and F-712 to the rear tail skin using clecos. I then fabricated the J brackets. I also bent the fuselage longerons to specifications (which was much easier than I expected it to be). I then attached the rear bulkheads to the lower fuselage skin and marked center lines on the J brackets.
