Brief Description: Bottom of Ribs Dimpled; Pitot Tube Mounting
Today, I began by dimpling the bottom of the wings. My heated Dynon pitot tube later arrived. I then began working on the pitot tube attachment. I fabricated an L bracket and riveted it between the wing rib and the pitot tube back plate. I then drilled all holes and cut the pitot tube hole in the wing skin. I then prepped and primed the pitot tube bracket. I then attached the pitot tube heat module to the rib.
