Brief Description: Spars Attached to Stand, Ribs Attached to Spar
Today, I attached my main wing spars to the wing stand I built earlier. I then attached all wing ribs to the main spar and attached the rear spar to the ribs using clecos. I then drilled all spar to rib holes to the propper size. Next, I disassembled the wing skeleton in order to debur and prime the wing ribs.
