Stans Web Site
Date:  4-1-2009
Number of Hours:  1.25
Brief Description:  Battery door
Put anti-chafe cover strips around battery door. Per the instructions I covered the entire door opening and made sure that I had glued sufficiently all around. Then cut the opening. I glued the edges around the interior and around the lip of the door frame and ironed all around to seal the edges.
Door from inside
Door from inside
Door coverd over from outside
After gluing & cutting
