Brief Description: Prep engine to mount on airframe
I completed the bolts on the engine including safety wired. I reintsalled the water hoses onto the spider at the rear of the engine by routing the hoses thru the engine mount tubes. I rotated the outlet nozzle to the lower right side. I began the install of the oil pressure switch.
