I installed the coolant hose to from the radiator to the expansion tank with the spring in the recommended position and the anti-chafe sleeve in place.
I installed the oil cooler and began to install the hoses only to discover that I did not have the fittings supposedly supplied with the engine. Talking with Rans informed me that Rotax had changed their methods so I ordered the parts.
I torqued the engine mounts bolts to 190+ inch/pounds.
