Stans Web Site
Rans S7-S
install floorboards
Install front wear plates. Had to remove & reinstall the left wear plate due to having sanded, polished & clear coated the wrong side.
Install front floorboards.
Install left rear floorboard with wear plate.
Install ELT mount floorboard.
Install rudder pedal left rear.
Install oil tank vent line, rudder return spring, grind & install rudder return spring and 1 fuel drain for carb drip pan.
Rans S7-S Home
1432
Control Systems
Covering
148
338
211
Hardware
Insturment Panel
393
199
Wiring
