I came home from work a little early and decided to finish drilling the left wing. I reamed all of the holes on the bottom skin of the left wingI then checked the right wing skeleton and adjusted for sag and twist. Then I fitted and clecoed the top and bottom skins for the right wing. That is a tiring job because many of the clecoes have to be forced a little into the holes to get the ribs lined up. I must have set and removed thousands of clecoes. My wrist is very sore..Now, both of the wings are in the jig with the top and bottom main skins on. They look good.
