Brief Description: Finishing wing jig and placing left wing in it
I went to Home Depot and purchased two 8' sections of aluminum angle to fabricate the braces for the upper arm of the wing jig and the lower arm. I cut the angle braces to size and then installed them on the upper wing jig arms so that they will remain level when the wings are on them.I cut a notch in the upper arm on the wing tip side to provide for clearance when the wing skins overhang the tip rib.To compensate for the wing sag, I fashioned an old carrige bolt and nut into a jack screw by drilling a hole in the shop stool seat and placing the bolt in there. The nut and a large washer keep the bolt from falling through the hole and provide height adjustment. It works just right.
Vicki helping lift the wing into the jig
Notch in the upper arm to provide for skin clearance
