Today I purchased a 12" long 7/16" drill bit to finish drilling the interior wing walk ribs for the pitot line. This new line of holes was below the other line (it is above the holes in the photos because the wing is upside down) so that I will have clearance to tighten the fuel tank attach bolts. I then installed the heated pitot electronic board to the wing rib with three nut plates, screws and spacers to keep the back side of the board off of the metal wing rib. I then fit in a full sized pvc pipe (which I purchased from the RV Aircraft section of Home Depot today) through the ribs (in holes Sam Beale and I drilled a few days ago) to act as the wiring conduit. Finally, I spot primed the countersunk holes in the rear wing spar and the flap brace.
Heated pitot electronic circuit board
The circuit board and the pitot mast
The wiring conduit (white) with the pitot line (silver) in the background, near the spar
