Brief Description: Deburred right wing leading edge
Tonight I started work on the right wing leading edge. First, I scored the blue plastic with a soldering iron to remove those strips where the rivets will be set. Then, I deburred the leading edge skin and the ribs. Finally, I drilled the strip which joins the leading edge skin and the tank skin for nutplates. No photos tonight, just more of the same.
