Tonight I sealed and riveted the last interior tank rib. It is the one next to the most outboard rib and it is easy to install once you remove the outboard rib.
Riveting this rib is easy because you can remove the outboard rib and get inside to buck the rivets
Once riveting is done, the easiest way to get proseal where you need it is a gloved finger
