It is great to be able to work on the plane two nights in a row. Tonight, I fabricated the right and left forward wing attach angles. I had to cut them from a big honkin aluminum chanel, sand the edges smooth and then polish the edges with the scotchbrite wheel. Then, I clamped them to the fuel tank forward attach angle (that was riveted to the fuel tank) and drilled the two attachment points into the fuselage. Believe it or not, that was a full night's work.
The forward wing attachment angles
Here is the left angle, clamped to the fuel tank attach bracket and clecoed to the fuselage on the lft
