Brief Description: More work on the fuselage top skin
Tonight Sam Beale came over and we worked on the fuselage top skin. I crawled into the fuse and match drilled some holes into the skin from the inside. I was unable to drill the last two holes because I snapped my 12" #30 bit. Then, Sam and I riveted on the corner gussets which strengthen the forward longeron/firewall connection.
