Stevens Web Site
Date:  11-11-2007
Number of Hours:  2.20
Brief Description:  Misc. nuts and bolts
Today was a big day in the family. Patrick, our middle son, left for Charlotte, N.C. where he will start his new job as an engineer at a wind tunnel facility. It was both sad and exciting. Later in the day, I slipped down into the basement to putter around on the airplane. I spent the time going through the entire elevator control system, checking to make sure that I had the right combinations of nuts, bolts and washers. Then, I disassembled the controls and bagged the hardware with each item so that I will not have to go hunting during final assembly. I also drilled out the aft control stick for its nut and bolt (it is removable). Next, I will work on the rudder control system.
