Brief Description: Working on the firewall, take two
Tonight was election night. I am really thankful I was down in the shop instead of in front of the TV, watching mindless progressions of numbers and political commentators. Whoever is in control of congress in the morning, I am sure that the sun will come up and the world will keep on spinning. Having pretty much finished the center section, I turned my attention to the replacement firewall parts. As you may recall, I screwed the pooch on Firewall No. 1, assembling and riveting it backwards. Tonight, I drilled out the firewall in the correct configuration and then deburred and dimpled it. Things seem to go smoother the second time around. It felt like deja vous all over again.
Drilled, deburred and dimpled (this time correctly) firewall
