I spent some time cleaning up the shop and vacuuming all of the sawdust created when I built the fuselage jig. Then, I took out the plans to start building the fuselage. We start with the stainless steel firewall. It is a prepunched thing of beauty. Then, I clecoed on all of the aluminum angle stiffeners/reinforcement angles as well as the steel weldments which act as doubler/backing plates for the engine mounts and anchors for the fuselage stringers. That is all I accomplished because I had to knock off to go pickup my oldest son Drew from the airport. He is visiting for the weekend from lawschool in Virginia.
Firewall with clecoed weldments and reinforcement angles
