I started on the rudder by cutting out the rudder stiffeners, sanding and then deburring them on the scotchbrite wheel. I then clecoed the stiffeners to the rudder skin and match drilled them. Last, I stripped channels of the blue plastic from the rudder skin with a soldering iron. When it came time for pictures, I had Vicki and Cookie (the cleco cat) join in.
Applying clecoes to the rudder skin and stiffeners.
