Brief Description: Horizontal Stabilizer front spar and skeleton
I had a big day. A package came from Avery with my 1/8 in. clecoes and a lightweight air hose extension. I installed the air hose extension and put the new (smaller) fittings on the rivet squeezer and the air drill. I started by bending the forward horizontal stabilizer spar reinforcement angles to 6 degrees. I then figured out the countersink so that I could countersink the 4 center holes on the reinforcement angles. I also used the pneumatic squeezer to dimple the forward spar in the center. I then constructed the horizontal spar skeleton as per the plans. Finally, I clecoed the left skin onto the left skeleton. It took a few tries to get it wrangled on. I ended up at 11 p.m. with a completely clecoed left horizontal stabilizer. Cool.
