It is Martin Luther King's birththday, which means I have closed the office. Of course, however, I went into work to get some paperwork done. Oh well, 1/2 day off is better than none. When I got home, I decided to slam one more tank rib in. I chose the second from the outermost rib, because you can remove the rib closest to the tip and have great access to buck the rivets for the second rib. Riveting went fine. As usual, it took longer to set up before and clean up afterwords than it took to actually rivet the rib in.On my next session (hopefuly with Jim) I can rivet the last two inner ribs. Then, I will only have the two outer ribs left. They should be easier because they can be readily accessed and they can be riveted with the squeezer.
